Posted: 2020-07-04 07:32 PM . Last Modified: 2024-04-04 11:11 PM
I need DDF file for parameter EasyLogic PM2100 - model METSEPM2130 , and ddf file for EGX 150 . please support me
(CID:132657523)
Dear nguyen van chung,
On a special resource Device Support you can find DDF-support already for a similar device from the PM2200 series:
You may to click on the button I WANT IT TOO and within a couple of business days you will be sent a web-link to download the DDF-file with the instruction.
If the above DDF-file does not work for you, then on the same resource you can make a new DDF-support request. How to do this is described in detail in topic and in video instructions.
You do not need to request a DDF-file for the TCP/IP Modbus gateway EGX150, as this does not make sense: you only need a DDF-file for your EasyLogic PM2100 devices.
With respect.
(CID:132657553)
With respect.
(CID:132657553)
Thanks for your answer , I had DDF of PM2200 but when I added device all parameter on DCE difference on PM2100
(CID:132657702)
In this case, you really need to make a new DDF-support request for your PM2100 device. Since, unfortunately, I also did not find ready DDF-support for your PM2100 device ☹️.
With respect.
(CID:132657704)
thanks Sir
(CID:132658691)
Posted: 2020-07-04 07:32 PM . Last Modified: 2023-10-22 01:47 AM
