Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
DCO
  • EcoStruxure IT forum
  • DCO
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:37 PM . Last Modified: ‎2024-04-08 01:53 AM
753
DCO
when I place the mouse cursor on a server it displays an information, how can I change the data that is displayed?
(CID:110795086)
  • Data Center Operation
There are two things that control the tool tip contents: current view and application preferences.
If you are in the "Power" view, tool tip contains information about power consumption and power connection, in addition to general information. Other views add their own properties.
You can also control the tool tip content from application preferences. See screen shot:
(CID:110795313)
(CID:110795313)
Hi Davis,
Tool tip would display the properties of the selected device, such as (in General settings) Model, Manufacturer, Type, Location, Serial Number and Barcode.
It is not supported to add/remove/modify the content/settings of the tool tip, but to change the properties of the server/device (that would be displayed in tool tip), we can right click on the server/device -> Properties, and then enter our new data:
Kind regards
(CID:110795327)
Posted: ‎2020-07-03 12:37 PM . Last Modified: ‎2023-10-22 01:47 AM
