DCO upgrade issue 8.1.0 to 8.2.2
  • DCO upgrade issue 8.1.0 to 8.2.2
127
Posted: ‎2020-07-04 04:42 PM . Last Modified: ‎2024-04-05 12:09 AM
668
Hello! I have issue described below. Upgrade logs attached webmin_dco_update.log
When you upgrade DCO from 8.x.x to 8.2.2 using the offline option in Webmin, the upgrade is unsuccessful.
If your setup requires the No third party RPMs and Do not download packages from the Internet options in Webmin, create a post in the Help Center community to request help with the upgrade. Our team will get in touch with you.
(CID:130097668)
  • Data Center Operation
Hi Nikita,
I will contact you directly to solve this issue.
The problem seen requires a special file to upgrade your Webmin module.
/Søren
(CID:130098279)
Hi Nikita,
/Søren
(CID:130098279)
Posted: ‎2020-07-04 04:42 PM . Last Modified: ‎2023-10-22 01:46 AM
