DCO upgrade issue 8.1.0 to 8.2.2
EcoStruxure IT Forum
  • DCO upgrade issue 8.1.0 to 8.2.2
Cory_McDonald
Cory_McDonald Champion
159
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:42 PM . Last Modified: ‎2024-04-05 12:09 AM
854
Hello! I have issue described below. Upgrade logs attached webmin_dco_update.log
When you upgrade DCO from 8.x.x to 8.2.2 using the offline option in Webmin, the upgrade is unsuccessful.
If your setup requires the No third party RPMs and Do not download packages from the Internet options in Webmin, create a post in the Help Center community to request help with the upgrade. Our team will get in touch with you.
(CID:130097668)
  • Data Center Operation
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Nikita,
I will contact you directly to solve this issue.
The problem seen requires a special file to upgrade your Webmin module.
/Søren
(CID:130098279)
Replies 2
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Nikita,
/Søren
(CID:130098279)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 04:42 PM . Last Modified: ‎2023-10-22 01:46 AM
