Posted: 2020-11-17 01:56 PM
Hi all,
The remote backup configuration video is no longer available.
A customer was trying to mount a nfs to DCO and is getting the following error message:
Failed to save mount : NFS Error - mount: wrong fs type, bad option, bad superblock on xxxx.com:/ifs/USA/NASHARED/struxureware, missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount. helper program) In some cases useful info is found in syslog - try dmesg | tail or so.
Looking at older posts seems like the problem is NFS utility is missing?
Posted: 2020-11-18 01:08 AM
Hi Orlando,
You are right, it seems nfs utility is needed.
SSH log in to server and then run the following command to install the utils (requires Internet access):
sudo yum -y install nfs-utils
Kind regards,
Hi Orlando,
Kind regards,
