DCO gemones update
  • DCO gemones update
129
72
Posted: ‎2020-07-03 01:04 AM . Last Modified: ‎2024-04-09 12:44 AM
1346
DCO gemones update
Dear guys,
I'm using DCO v7.5 and the genomes library is old. I not find some APC devices as Netbotz 570.
How can I update this genomes library?
Best regards,
Enric Climent
(CID:105468487)
  • Data Center Operation
Replies 13
Hi Enric,
The Genome Library is currently updated with new versions of DCO. if you have equipment that is missing you can create it yourself. more information can be found here:
Working with the Genome Library and Genomes
https://dcimsupport.apc.com/display/public/UAOp74/Configuring+Equipment+not+Available+in+the+Genome+...
BR,
Rana Ajmal
(CID:105468528)
Posted: ‎2020-07-03 01:04 AM . Last Modified: ‎2024-04-09 12:43 AM
Hello Enric, I saw Rana Ajmal's answer for your question. I work for the genome team in SE. If you can let me know those devices name which are not in 7.5 version, I can add those to the system and in the next DCO release. Regards Thejaswi
(CID:105468543)
Hello Thejaswi, There are some APC SKU not in DCO 7.5 genome library as NBRK0500, NBRK0200, NBPD0150 and AP7723, for instance. Regards, Enric
(CID:105468697)
Hello Eric, Thank you for the reply and I apologize for the inconvenience. I see that AP7723 is present in Genome library. But it will be available to use with the next Genome library release which is happening within this month. Also I have made the list of NBRK0200, NBPD0150 to add into the Genome software. However I was not able to find any info on the NBRK0500. Can you please cross check for this device name and confirm me so that I can add it to the software ASAP. Regards Tejaswi.
(CID:105468708)
Posted: ‎2020-07-03 01:05 AM . Last Modified: ‎2024-04-09 12:43 AM
Hi Tejaswi, It's not NBRK0500, I'm confused, really is NBRK0570. Regards, Enric
(CID:105468710)
Hello Eric, Thank you for the update. I have added this to the list as well. Please let me know if you have any other questions, I will be glad to help you. Regards Tejaswi.
(CID:105468711)
Hi, Please see the attached picture NBRK0200, NBPD0150 is also available in genome. for NetBotz 570 it is under Product Series: 500. Product Line: NetBotz Product Series: 500 Product Name: NetBotz Rack Monitor 570 Part Number: NBRK0570 BR, Ajmal
(CID:105468724)
thanks
(CID:105468725)
Hi Rana, Thank you for the update. Can you please let me know the version of DCO you are using. Thanks Tejaswi
(CID:105468795)
Hi Tejaswi, I am using 7.5.
(CID:105468876)
Hello Rana, Thank you for the update. Yes NBPD0150 is available under Netbotz rack sensor pod 150. But we have NBRK0201 under Netbotz rack monitor 200 not the NBRK0200 and NBRK0551 is available and not the NBRK0570. Regards Tejaswi
(CID:105469017)
Hi Tejaswi Manjunath, I've just found this thread, I would like to ask you: when is estimated to have the next genome library version available? do we have to wait until in the next DCO version? I have the DCO 7.5 version, and I had a list of devices that are not part of it and we need to include them in the library (I'm preparing this list). thanks for your answer.
(CID:106205029)
Posted: ‎2020-07-03 01:05 AM . Last Modified: ‎2023-10-31 10:49 PM
