Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: β2020-07-02 10:05 PM . Last Modified: β2024-04-09 01:34 AM
I have the DCO and Portal Servers running in VMware, however due to organisational changes we are moving to Hyper V.
Can these servers be converted from VMware to Hyper V or will they require rebuilding?
If they can be converted is this likely to break the applications?
(CID:105460002)
Hi Martin,
I would basically suggest a clean installation, and then restoring the latest backup.
Kind regards
(CID:105460004)
Since when is DCO running on Hyper V? I was allways told this is not working!! π
(CID:105460922)
Hi Ueli, Good catch, I think you are right, there might be problem with the network drivers of the Hyper-V manager - so the installation might not work. Kind regards
(CID:105460928)
Thank you both for your input π
I think it would be best for me to discuss with management about keeping these servers in VMware π
(CID:105460931)
Posted: β2020-07-02 10:05 PM . Last Modified: β2023-10-31 10:48 PM
