Posted: β2020-07-03 11:34 PM . Last Modified: β2024-04-05 04:53 AM
With DCO LAB 8.1 when I try to put an asset in a rack after create a new room I get the following java error
Best regards,
Enric Climent
(CID:125209548)
Posted: β2020-07-03 11:35 PM . Last Modified: β2024-04-05 04:52 AM
Hi Enric,
I can confirm the reported issue - it seems it is not limited to the Spanish language, but actually all non-English LAB client generates the same nullpointer exception when adding powered device into a rack.
I have registered an enhancement case for this (bug report!).
Many thanks for reporting,
Kind regards
(CID:125210396)
Hi Enric,
I'm able to create a room, add a random rack and server without any problem in my LAB 8.1.
Which items (from Genome Library) are you using? then I will do a similar test, thanks.
Kind regards
(CID:125210024)
Posted: β2020-07-03 11:35 PM . Last Modified: β2024-04-05 04:53 AM
Hi Jef,
I've detected in English not happens the problem, try with Spanish language please. It happens with any item.
Enric
(CID:125210388)
Hi Enric,
Kind regards
(CID:125210396)
Posted: β2020-07-03 11:35 PM . Last Modified: β2023-10-22 01:38 AM
