DCO EE: ups input or output sensor for script?
  • EcoStruxure IT forum
  • DCO EE: ups input or output sensor for script?
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:48 PM . Last Modified: ‎2024-04-03 02:52 AM
899
SSIA,
  • when configuring DCO Energy Efficiency, for the ups script, should I be using UPS input power sensors or UPS output power sensors?  I assume I should be using the input power sensors, but have been told to use the output sensors by other colleagues.
  • If I use a script, will DCO use the PU data and other fields that are in the EE tab of the device properties?
  • Same question goes for PDUs?  I'd assume you'd use the output sensors.
Thank you.
(CID:141272358)
  • Data Center Operation
899
Hi Andrew,
Input sensors should be used for scripts (both for UPS and PDU). Device (UPS/PDU) configuration settings (such as Typical PU) should also be specified.
Kind regards
(CID:142051085)
Replies 5
anyone?
(CID:142051011)
900
Hi Andrew,
Kind regards
(CID:142051085)
Posted: ‎2020-07-05 06:48 PM . Last Modified: ‎2024-04-03 02:51 AM
Thank you for confirming!
(CID:142051260)
You are most welcome, Andrew
Kind regards
(CID:142051385)
Posted: ‎2020-07-05 06:49 PM . Last Modified: ‎2023-10-22 01:36 AM
