Posted: 2020-07-06 01:07 AM . Last Modified: 2024-04-02 11:20 PM
Good day
Can you assist me with resolving the issue of DCO failure to represent details on the Energy Efficiency dashboard. I can see the PUE on the portal as well in the DCO EE Configuration page when I run an evaluation. When I run the dashboard it gives no info but only displays when I request for over a year ago.
Is there something I can do. I have tested from different browsers getting the same results.
Kind Regards
Mate.
(CID:153945244)
Hi Team
I managed to resolve the issue. I had to revisit all the scripts for some of them were failing to return real-time data.
Thank You
Mate.
(CID:153945366)
Posted: 2020-07-06 01:07 AM . Last Modified: 2024-04-02 11:19 PM
Dear Mudzimu Mate,
Ok, very thanks for the good feedback. You can mark your answer as resolved 😀.
(CID:153945539)
Posted: 2020-07-06 01:07 AM . Last Modified: 2023-10-22 01:36 AM
