DCO Device Association
  • EcoStruxure IT forum
  • DCO Device Association
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 08:20 PM . Last Modified: ‎2024-04-03 01:15 AM
883
Example: We do see the devices in our DCE, it also appears in the DCO under "discovered devices", but we can not associate it . It also does not show under "unassociated device".
Thanks for any hint, Adrian
(CID:146277581)
  • Data Center Operation
Replies 6
Hi Adrian,
Can I ask for:
copy of the latest backup file
screen capture(s) illustrating the "problem" devices, so I can find them in the setup.
I will send you an invite to my =S= box shortly so the data safely can be shared with me, thanks.
Kind regards
(CID:146669825)
882
Hi Adrian,
Many thanks for providing the useful data. I have sent you a direct response moment ago. It seems the rack pdu device you are looking for, is from the DCE server "isx02*" which is not integrated in DCO.
The item/device you are seeing under the discovered devices is a different item (switch device) and coming from another integrated DCE server ("glc*).
In DCO, desktop client, System Setup > External Systems Configuration, would display the list of the integrated external servers.
Kind regards
(CID:146671375)
Hi Jef, as stated, isx02 is an alias of the server you see as external server. The issue is somewehere else.
Adrian
(CID:147194740)
Hi Adrian,
Many thanks for the info that have also been provided offline. Currently looking into this & will get back to you as soon as I have some answers, thanks.
Kind regards
(CID:147194742)
Hi Adrian,
Solution suggestion to resolve the issue is provide by direct email (moment ago), thanks.
Kind regards
(CID:147195293)
Posted: ‎2020-07-05 08:21 PM . Last Modified: ‎2023-10-22 01:36 AM
