Posted: 2020-07-05 08:21 PM . Last Modified: 2024-04-03 01:15 AM
How can we read "Measured Average Power Loads"? DCO Analytics tool does not provide any data, also ETL "dbo.swo_kpi" seems to miss this figure.
Thanks, Adrian
(CID:146277590)
Hi Adrian,
If we right-click on associated device (such as UPS or rack pdu) > Properties > External Systems > Device, then we should be able to read the measured average power (based on user defined period, default is 30 days):
Kind regards
(CID:146669820)
Hi Jeff. Yes, I do see those values. How do I get them via ETL or in the Analytics tool?
Regards
Adrian
(CID:146670867)
Hello Adrian
If you query the configuration_item_power_path table for the ci_id of the PDU do you see the average power values you expect to see in the pp_average_power field?
Sample query would be:
select * from configuration_item_power_path where ci_id = '
In some cases this table may have the value you're looking for.
Regards
GregS
(CID:147194042)
HiGreg
Thanks for your helpful answer!
We actually do get some figures with your query from a DCE we have in the US. Unfortunately we do not get any value (NULL) from other DCEs we have installed in other places. This is odd. I start to believe that this is related to other issues we have with device associations.
Regards
Adrian
(CID:147194729)
You are correct. If your device associations are incorrect then the results in the export database will be inconsistent. They are worth checking.
Regards
Greg Sterling
(CID:147194837)
Posted: 2020-07-05 08:21 PM . Last Modified: 2024-04-03 01:14 AM
Hi Jef
They wanna have this "Average Power Load" available in ETL
Adrian Jeitziner
(CID:146671517)
Posted: 2020-07-05 08:21 PM . Last Modified: 2023-10-22 03:01 AM
