DCO DR node - frequency for synchronisation job
  • EcoStruxure IT forum
  • DCO DR node - frequency for synchronisation job
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 11:17 PM . Last Modified: ‎2024-04-03 12:11 AM
1625
Hi Team,
Could you please advise what is the frequency for the DCO DR node updates?
Once the DCO DR node has been attached to the main DCO server the sftp connection is established...how often will the transfer between the two happen?
Trying to establish the maximum expected data loss for the DR scenario.
For example:
If the synchronisation happens every 15min and it takes between 5-15 minutes to complete than in a worst case scenario we could expect that 30minutes worth of changes done by the DCO users will not be available in an event of the PROD DCO failing...
(CID:151063079)
  • Data Center Operation
Replies 9
1625
Lukasz
The following is documented on the page https://sxwhelpcenter.ecostruxureit.com/display/public/UADCO8x/StruxureWare+Data+Center+Operation+Ne....
Based on some data usage testing we found that the minimum requirement for running a DR node on a 200 rack solution is 10 Mbit/s. This of course varies by usage, but unless the user performs multiple changes to the entire solution in short succession, the DR node will stay in sync within a few minutes on a 10 Mbit/s connection even with larger changes (e.g. adding 50 racks). For most common tasks, the DR will be sync'd within seconds. DCO also has a large buffer (8 GB), so the DR node will be able to catch up even if there are many changes at once, it will simply be a few saves behind the main node (however, still in a consistent state).
Regards
Jim
(CID:151063106)
Thanks Jim,
This refers to PostgreSQL and the whole section is titled "Disaster recovery node and cluster related protocols" so my suspicion is that this long description is actually talking about the way CLUSTER would synchronise and not how the PROD and DR nodes would...
(CID:151063121)
Posted: ‎2020-07-05 11:17 PM . Last Modified: ‎2024-04-03 12:10 AM
Lukasz Staciwo, Cluster is no longer an available option on DCO. This documentation refers to DR nodes.
(CID:151063276)
Thank you Jeff Shaw
I am well aware of cluster setup not being supported anymore.
What I am saying is that the description on the above article refers to PostgreSQL ports which were previously used when cluster was available...I do not believe that DR DCO node uses PostgreSQL port to synchronise with PROD DCO node...
This page probably needs updating and my question still remains as per original post...
(CID:151063458)
Posted: ‎2020-07-05 11:18 PM . Last Modified: ‎2024-04-03 12:10 AM
Hi Team,
Could you please advise?
Is the answer that Jim pointed me to describing the DR node operation and not the cluster setup? If yes that is great...I am just not sure if PostgreSQL ports are being used by DR node...
(CID:151064473)
Hi Lukasz,
Yes, Jim has pointed to the correct documentation. The description is also valid for the DR node.
Kind regards
(CID:152077145)
Thank you Jef Faridi
Could you please requirest tha the documentation page is updated to remove the cluster references since it is no longer valid. If this desciption is valid for DR node does it mean that DR node uses  PostgreSQL on port 5432. to commnicate with Production DCO node?
(CID:152077530)
Hi Lukasz,
You are most welcome. Documentation will be updated soon (for the time being intentionally cluster description is not removed yet). Yes, postgresql on port 5432 is used to sync the data between master node and the DR.
Kind regards
(CID:152077722)
Posted: ‎2020-07-05 11:18 PM . Last Modified: ‎2023-10-22 01:36 AM
