Failing to create energy report DCO
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • Failing to create energy report DCO
126
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-05 11:18 PM . Last Modified: β€Ž2024-04-03 12:10 AM
1173
I have a DCO installation running the latest version that is failing to run the energy report.
The report is usually run for two sites each month, the 1st site the report will generate normally, but it fails for the second site with the error;
I have a client (Baillie Gifford) who are having problems with their DCO installation when trying to run an energy report. They have a couple of locations and in the primary location the report will run successfully but when they try to run it for the site called Calton, they get an error stating;
There was an error generating the report. See the client log file for more information.
I have looked at the logs but it seems there are a number of JAVA errors.
Can anyone provide any assistance.
(CID:151063154)
  • Data Center Operation
1173
Hi Alastair,
Many thanks for providing the useful log files, they contain the info I could use. It seems this report creation contains some unhanded exceptions, which appear to be software bug that we have recently discovered and will be fixed in the next release version.
Kind regards
(CID:151063610)
Replies 7
Hi Alastair,
Is it possible to ask for the following data:
  • backup file
  • screen capture(s) illustrating the reports/issue
  • client application.log file (usually located in C:\Users\\.isxo\\Operations )
I will send you an invite to my =S= box shortly, so the data safely can be provided to me (if you would), thanks.
Kind regards
(CID:151063168)
Hi Jef,
I have uploaded the log files, and requested the other files, will upload when i have them.
(CID:151063174)
1174
Hi Alastair,
Kind regards
(CID:151063610)
Posted: β€Ž2020-07-05 11:19 PM . Last Modified: β€Ž2024-04-03 12:10 AM
Hi Jef,
Many thanks for the response, i take it there is nothing else that can be done at the moment and you don't need the other files that you have mentioned before now?
(CID:151063733)
Hi Alastair,
That's correct, there is nothing else we can do at the moment and we don't need to get other files. Your kindly provided logs did contain the info we needed. Many thanks.
Kind regards
(CID:151064006)
Thanks for your help Jef πŸ˜€
(CID:151064061)
Posted: β€Ž2020-07-05 11:19 PM . Last Modified: β€Ž2023-10-22 02:05 AM
