DCO / Cooling / Error message
  • EcoStruxure IT forum
  • DCO / Cooling / Error message
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:39 AM . Last Modified: ‎2024-04-09 12:51 AM
511
Hello. I have this error message when I try to use the colling vue.
Can someone help me please.
Best regards
rma
(CID:105467472)
  • Data Center Operation
Replies 4
Posted: ‎2020-07-03 12:40 AM . Last Modified: ‎2024-04-09 12:51 AM
Hi Mancino, Can you please add some screen capture(s) illustrating the location of your vertical grilles. Would it possible to ask for a copy of the latest backup file? I will shortly send you an invite to my box, just in case if you would share your solution with me, thanks. Kind regards
(CID:105467765)
511
Hello A collegue solved the issue yesterday afternoon: the left and right walls were not perfectly right! There was a very small angle with the grid so that the vertical grills were not perfectly aligned with the walls and consequently a part of the grills was outside the room… Tks for your answers. Regards Rocchino
(CID:105467770)
Hi Rocchino, Great!, many thanks for the update and explanation for how it is resolved, really appreciated. Kind regards
(CID:105467772)
Posted: ‎2020-07-03 12:40 AM . Last Modified: ‎2023-10-31 10:48 PM
