Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
DCO. Colo. Wrong equipment owner in a cage.
  • EcoStruxure IT forum
  • DCO. Colo. Wrong equipment owner in a cage.
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:06 PM . Last Modified: ‎2024-04-08 12:19 AM
849
How it is possible to get a warning or report in case if an equipment which is owned by one customer has been installed in the rack which is owned by other customer in DCO with Colo license?
In version 8.1 it is only small yellow lamp in equipment customer tab indicates that something went wrong.
(CID:120133969)
  • Data Center Operation
850
Hi Dmitry,
As you might have noticed, if/when "mis"-configuring user would be notified that the selected company name dose not mach the company name of parent equipment:
However, if you/customer would be interested in additional feature, then please feel free to send me the description then I will register it (or you might want to post it here: Feature requests thanks
Kind regards
(CID:120134371)
Replies 4
851
Hi Dmitry,
Kind regards
(CID:120134371)
I think that is good idea to add field in owner to 'Inventory' report.
(CID:120134815)
Hi Dmitry,
Many thanks for your comment - I had a quick look, it seems we already have a report option that is called "Customer Inventory", thanks.
Kind regards
(CID:120134907)
Posted: ‎2020-07-03 05:06 PM . Last Modified: ‎2023-10-22 01:36 AM
