Posted: 2020-07-04 02:30 PM . Last Modified: 2024-04-05 02:36 AM
Hi team,
is there any option to collapse the capacity overview whe DCO opens maybe modifying struxureWare Data Center Operation.ini?
I contract manually all the sites, but when I open DCO again, capacity overview appears expanded. We are now in a deploy with 30 countries and we will like to see the overlay diagram contracted, to quickly locate the DCs in only one level map.
(CID:128760985)
Hi Javier,
Sorry to disappoint, there is no way to customize/modify the Global view. Functionality of the Global is basically to display the capacity information for all location, so when we start the client it would show all capacity overview's as designed.
Kind regards
(CID:128762964)
Hi Javier Zurera, thanks for posting. Let's hope you find your answer here. Kind regards Ditte
(CID:128762127)
Hi Javier,
Kind regards
(CID:128762964)
Posted: 2020-07-04 02:30 PM . Last Modified: 2023-10-22 01:35 AM
