Posted: 2020-07-04 02:29 PM . Last Modified: 2024-04-05 02:37 AM
Hi all!
After upgrade to DCE-7.5.0, I found the above problem: that is, if rPDUs are connected together by a chain (via A-Bus link), then all sensors "Device n - Power, Bank m" are switched to the Unplugged state.
This problem occurred because of an error in the DDF-file apcpower.xml v.47. Below is my diff-file, which shows where you need to make corrections to fix the above error:
diffdiff apcpower.xml apcpower_mod.xml2740,2759c2740,2745 <After making the above changes, we finally get a fully working DDF-file apcpower_mod.xml, and the above problem with Unplugged sensors disappears.
I hope the DDF team will analyze this problem and make the necessary corrections.
With respect.
(CID:128760819)
Thanks or your input, my team will have a look at this,
(CID:128760833)
Thanks for the quick feedback 😀.
(CID:128760850)
Posted: 2020-07-04 02:30 PM . Last Modified: 2024-04-05 02:37 AM
Dear Jesper Thomsen,
Unfortunately, the DCE-7.6.0 upgrade showed, that the above mentioned problem has not been resolved (the DDF-file apcpower.xml v.50 is used).
This is bad ☹️.
With respect.
(CID:137105519)
Posted: 2020-07-04 02:30 PM . Last Modified: 2024-04-05 02:36 AM
For this annoying problem, I created the corresponding Request modification:
Hope to get a quick feedback...
(CID:137105529)
Posted: 2020-07-04 02:30 PM . Last Modified: 2023-10-20 04:59 AM
