Posted: 2020-07-02 03:58 PM . Last Modified: 2024-04-09 02:58 AM
Hi guys,
Could you please point me into the right API to read (if one exists) where I can read DCE alarms from DCO?
I presume ideally we should read that info from DCE but I would like to find out if it is possible to get it from DCO.
Reason behind is that we have one DCO server and multiple DCE servers.
Another reason is that DCEs are monitoring many devices that are not required in DCO (not associated).
(CID:103583977)
Hi Lukasz,
You should read the alarms direct from the DCE server and not the DCO server. I am pretty sure we don't expose a alarm API in DCO.
I understand what you are trying to do, but you will need to get the data from DCE and then create your webservice calls so you only get the required alarms from the devices you uses.
Jesper
(CID:103583987)
Hi Lukasz,
Jesper
(CID:103583987)
Posted: 2020-07-02 03:59 PM . Last Modified: 2024-04-09 02:58 AM
Thanks Jesper.
(CID:103584432)
Posted: 2020-07-02 03:59 PM . Last Modified: 2023-10-31 10:48 PM
