Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
DCO 8.3.2 Adding Users
  • EcoStruxure IT forum
  • DCO 8.3.2 Adding Users
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 11:01 PM . Last Modified: ‎2024-04-03 12:16 AM
587
When I try to add users using my authentication servers, it gives me an error of Authentication Server is required
I just recently upgraded to DCO 8.3.2. I have added multiple people using this AD previously and had no issues.  I have even deleted a user to test and was unable to re-add them due to this error.
(CID:150241873)
  • Data Center Operation
Hi Richard,
If the only change is the DCO upgrade, I was wondering (only guessing) perhaps it might be certificate related issue, if "Use encryption/port 636" is used for the communication. The possible certificate change on AD server will not be automatically updated in DCO, it needs to be updated manually. It can be done via web-client, Settings (wheel icon) > Authentication Servers, and then Edit the integrated AD server and push the OK button.
You might also want to test using the un-encryption option/port 389, and see the outcome.
Kind regards
(CID:151062035)
Posted: ‎2020-07-05 11:01 PM . Last Modified: ‎2023-10-22 01:33 AM
