DCO 8.2.x - Change assign work order process to existing asset?
  • EcoStruxure IT forum
  • DCO 8.2.x - Change assign work order process to existing asset?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 01:21 PM . Last Modified: ‎2024-04-04 12:34 AM
736
I apologize if I missed it somewhere, but it didn't seem to be an intuitive thing.  Is it possible to create a work order with a static work order process (eg server maintenance) and assign it to an asset so it can be used with an audit log or have some other tie to the existing piece of equipment?
(CID:134688655)
  • Data Center Operation
Not sure how I missed it, but I'm pretty sure I found it.  To apply a process to the asset, you can right click it and choose apply work order process.
(CID:134688844)
(CID:134688844)
Posted: ‎2020-07-05 01:21 PM . Last Modified: ‎2023-10-22 01:33 AM
