Posted: β2020-07-05 04:48 PM . Last Modified: β2024-04-03 04:22 AM
Hi ,
I have a problem accessing from browsers to the server
I receive an error message and can not enter a user name and password
Has something encountered a problem and what can be done to repair
The problem appeared in Chrome and Explorer browsers
The DCO server was also restarted and the problem did not disappear!
i attached the masege
MISSING IMAGE: IMG-20190131-WA0002.jpg
Best regards
Yaniv Rozenbaum
(CID:139691642)
Many thanks for all the help
the problam fund it is new monitoring system on the costemer
net it did not give the acsses to the web
the IT of the customer working to fix the problam
Yaniv
(CID:140219097)
If you logon to webmin and check the status of the dco server does the status page state DCO services are running? If yes, are you able to login with the desktop client?
Greg Sterling
(CID:139691814)
Hello Yaniv.
You are using local user accounts when you try to login or are they domain based user accounts?
Can you share the server logs from your server so we can check whether the server itself is reporting problems with authentication or otherwise?
There is a download log files option in the struxureware menu of older DCO releases (8.2.7 and earlier) and in the web client in 8.2.12 and newer DCO releases. I assume you cannot use the web client method if you're running 82..12. If you need to use the webmin method, then you can manually download the server.log file from the "upload and download" menu under the system menu in webmin. Full path to the server.log file is "/opt/jboss-as/standalone/server.log".
Greg Sterling
(CID:139692418)
Hi Yaniv,
Do you recall when this web client issue appeared for you? and do you know what system changes that might have been applied before appearance the issue?
To have a more understanding of the issue and see more detailed log entries, additional to server logs it would also be great to a have screen dump of the browser developer tools (in Chrome, top right menu, More tools>Developer tools).
If there have been some system changes (that you are not aware of or don't remember), then perhaps a clean instillation and then restoring the latest backup file could be an option.
Kind regards
(CID:139693253)
Yaniv
(CID:140219097)
Posted: β2020-07-05 04:48 PM . Last Modified: β2023-10-22 01:33 AM
