Posted: 2020-07-03 04:26 PM . Last Modified: 2024-04-08 12:38 AM
I'm trying to use the asset provisioning tool in DCO 8.1 and for some reason almost every rack always has "Watts Per U Height" as yellow or red, never green, even in a completely empty rack, regardless of what equipment I choose.
can anyone explain this recommendation better and what it would it requires for it show green instead of yellow? In my example above, I was using a 300 W server and 8.6 kw rack pdus
(CID:119050632)
My best guess is that Operations is warning you that if you continue to add 185W servers (as is the load shown in the screenshot) you will run out U-space before using all the capacity in the rack.
44 servers of 185W: 8.14 kW
Capacity of each rack PDU: 8.6 kW
Hope this helps.
Best,
Niels
(CID:119050828)
Hope this helps.
Best,
Niels
(CID:119050828)
Thank you both, Niels was right, changing it to a 500w 1U server made some green racks. I assume there isn't way to disable/ignore specific placement advisor suggestions is there?
(CID:120129569)
As Niels pointed out, "Watts Per U Height" is there to avoid stranded power capacity, if you try with a 1U server of 500W the "Watts Per U Height" should go green.
Or if you do not intend to use the full rack PDU capacity in a rack, you could set a design limit on the rack, which more matches the "power use" of servers you want to use.
BTW: "Watts Per U Height" never goes red, so the red racks are caused by something else.
Best,
Gert
(CID:119050977)
Posted: 2020-07-03 04:26 PM . Last Modified: 2023-10-22 01:31 AM
