DCIM Email notification error
  • DCIM Email notification error
129
112
72
Posted: ‎2020-07-03 03:40 AM . Last Modified: ‎2024-04-08 11:54 PM
1166
is it possible to DCIM email notification configure with global smtp source like Gmail,Yahoo ??
Also share if the customer do not have any web mail server or SMTP port address then possible to configure email notification with another web mail server or port address....
Need your expertise.
Mukesh
(CID:106206955)
  • DCIM Support
Replies 5
1166
Yes, please take a look at Configuring E-mail Settings.
(CID:106207002)
Thanks for reply......
But in case customer does not have any mail server or SMTP address facility then we can configure email notification with another SMTP source in existing network area.
One more question is it possible to DCIM email notification configure with Global SMTP address like Gmail, Yahoo etc ???
(On behalf of mukesh_ele_mail, moved comment from the user assistance)
(CID:106207178)
Posted: ‎2020-07-03 03:41 AM . Last Modified: ‎2024-04-08 11:54 PM
By following the instructions in my link, you can add an SMTP server. The SMTP server can be on your local network or on the internet if the DCO server has access to the internet. I believe you would normally use an internal SMTP server but technically it should be possible to use e.g. Gmail SMTP servers, provided that you set it up correctly according to the requirements of the particular service. Please consider what you are doing before sending internal information (in the mails sent via the SMTP server) through an external SMTP server. Also, please make sure that the internet does not have access to the DCO server, for security reasons.
(CID:106207180)
I want configuration steps for email notification thru external SMTP like Google SMTP. We are sure that the internet does not have access thru DCO Server. Do the need full...... Regards, Mukesh
(CID:106891297)
Posted: ‎2020-07-03 03:41 AM . Last Modified: ‎2023-10-31 10:46 PM
