DCE surveillance license is able to catch cameras from 3rd party vendors ?
  • DCE surveillance license is able to catch cameras from 3rd party vendors ?
129
72
SESA380953
SESA380953 Schneider Alumni (Retired)
Posted: ‎2020-06-12 12:41 PM
2792
Hi All:
Does anybody knows if Data Center Expert surveillance license, is able to catch cameras from 3rd party vendors ?
Thank you in advance.
  • DCIM Support
  • IT Expert
  • NetBotz
  • Tips and ideas
Captain
Posted: ‎2020-06-12 04:33 PM
2
2784
StruxureWare Data Center Expert Surveillance  can only work with cameras connected to a NetBotz appliance. For version 3 appliances, this means the NetBotz camera pods and any Pelco cameras documented in the Knowledge base at APC.com or in the firmware release notes. They should be the same.
For the NetBotz 750, you can use the NetBotz IP camera pod 165 (NBPD0165). His is the only camera pod that supports motion detection on the 750. No 3rd party cameras are listed as officially tested but any camera that supports the ONVIF ‘S’ protocol should be discoverable. Please note that motion detection is not supported by that protocol.
thank you,
Steve.
Captain
2
2785
thank you,
Steve.
Posted: ‎2021-04-10 01:23 AM
In response to APC_Steve
2424
Hi Steve,
Sorry i just wanted to confirm if the Netbotz 750 with Camera Pods 165 would require a DCE Surveillance license or not.
Reason i ask is that the design portal does not add the surveillance license.
Kevin
Captain
Posted: ‎2021-04-10 09:09 AM
In response to Anonymous user
Hi @Anonymous user
if you want to see images from a 755/750 in DCE, you must have surveillance licenses in DCE. Unlike the old 300/400/500 series NetBotz that sent everything to DCE via http/https, everything from the 700 series except images are sent via SNMP. This means there is no connection from alerts on a 75x to its images and the only way DCE can receive them is through its surveillance feature.
Steve.
