We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Posted: 2020-07-03 06:46 AM . Last Modified: 2024-04-08 10:41 PM
Hi fellows,
I have set the email settings in DCE server 7.2.0 so that when an alarm occurs an email should be sent to the client, and when we press test e-mail settings button we get a successful test message but the client email doesn't receive any email, how van I solve this issue.
BR,
Sameeh
(CID:108827797)
Hi Sameeh,
There could be a number of reasons for this failure. Please make sure the test and the actual e-mail are using the same "to" and "from" e-mail addresses. You may also want to check your spam folder as potentially some of the information contained in the actual alert e-mail is being flagged by your system.
Check the logs on your e-mail server. Does the server report that DCE actually sent the e-mail and the server perhaps denied it? Make sure the e-mail alert action is properly associated with either the device or with the threshold you've configured. This knowledge base document is a quick run-through of how to set it up correctly.
You can also run a packet capture on the network to see if the server is actually trying to send the e-mail. Packet captures will show trafic both ways so if we're not reaching the SMTP server or if there is a reason the server is denying the e-mail, you may see info there.
Steve
(CID:108827857)
Posted: 2020-07-03 06:46 AM . Last Modified: 2023-10-22 01:27 AM
