DCE report export file can not support Chinese words?
  • EcoStruxure IT forum
  • DCE report export file can not support Chinese words?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 06:23 PM . Last Modified: ‎2024-04-07 11:53 PM
954
Hi Team ,
About our report function on DCE , it's appear fault when I export to TXT or EXCEL file , Please
refer as below screenshot .
This error seems concern Chinese words , is this relate Chinese issue or words format like Big5, unicode?
Will this issue can fix on new version in the future ?
Best Regards
(CID:122693448)
Replies 5
954
Hi
The CSV file format does not have any information about text encoding. You may need to tell MS Excel in which encoding is your data. Try the following:
  1. Open MS Excel and create a new workbook
  2. Select "File > Import"
  3. Locate your CSV or TXT file and click "Get Data"
  4. In Text Import Wizard try different encodings to make your data readable.
(CID:122693558)
Hi Stanislav,
Thanks for the instruction , I already got the result after test , I can encoding to simplified
Chinese when I login to client for Chinese version, can't encoding if I login to client for
English version . It's have some problem if the words include traditional Chinese.
Anyway , when will DCE support traditional Chinese ? Any plan on it ?
Best Regards
(CID:122694237)
In the next major version update. But I don't know when this will happen.
(CID:122694244)
Ok , many thanks.
(CID:123340815)
Posted: ‎2020-07-03 06:23 PM . Last Modified: ‎2023-10-22 01:27 AM
