DCE and Netbotz 750 DDF
  • EcoStruxure IT forum
  • DCE and Netbotz 750 DDF
126
65
Back to EcoStruxure IT forum
jonchill
jonchill
Cadet
Posted: ‎2022-06-13 07:52 AM
1761
We're currently running DCE v7.9 and I'm trying to add a Netbotz 750 v5.3.4.52 and following the Netbotz instructions I still get a critical issue.
I can do remote configuration of the 750 and all sensors and the 3 cameras we have are all working from DCE.
I did find a different post regarding this issue with v7,8 and that was resolved by enabling ping on the firewall, we don't have a firewall between DCE and the 750.
All our 250's work fine.
How can I resolve this and have it show as green rather than red critical?
Any help would be much appreciated.
Jon
  • NetBotz
Replies 7
Shaun
Commander Shaun Commander
Commander
Posted: ‎2022-06-13 07:56 AM
1756
Hi @jonchill,
Could you share the text of the alert you're getting?
  Shaun
jonchill
jonchill
Cadet
Posted: ‎2022-06-14 12:23 AM
In response to Shaun
1727
This is the error I'm getting, I know the root login works as I can login to the CLI using the same username and pwd.
Make sure 'Device File Transfer Settings' lists the Username, Password and IP Range combination needed to access this device. Also make sure the device is connected to the network and operating normally, with the file transfer protocol enabled. If the problem persists, contact APC Support
Bunton874
Bunton874
Cadet
Posted: ‎2022-06-21 03:06 AM
In response to jonchill
1636
I am also looking for a solution, Because I am also getting a same issue. Please help! What do we have to do?
Tafadzwa
Lt. Commander Tafadzwa
Lt. Commander
Posted: ‎2023-03-07 02:03 AM
In response to Bunton874
Hi Bunton874,
Did you finally get a resolution to this problem? I am having the same challenge.
TIA.
Connecting Devices!
jzurera
Lt. Commander jzurera
Lt. Commander
Posted: ‎2023-03-07 02:26 AM
Maybe with new firmware 5.3.5 these integrations problems with DCE will be solved. I do not know if this new firmware is already available.
Shaun
Commander
Posted: ‎2023-03-07 03:12 AM
1187
Sorry, I forgot to follow-up on my last query.
Can I ask what version DCE you're running?  7.9.3 has some improvements that specifically target this.
Tafadzwa
Lt. Commander
Posted: ‎2023-03-07 07:39 AM
Hi Shaun,
I am running DCE v7.8.1 and NetBotz v5.3.4.52.
Connecting Devices!
