Posted: 2020-07-03 04:53 AM . Last Modified: 2024-04-08 11:31 PM
I have installed PME 8.1 and DCE 7.3.1 with Modbus TCP module.
When I try to read some data in PME from DCE, I get an "Invalid data address" modbus error. It is not a timeout, so the communication is working.
Can you help me connecting the two softwares together?`
The information about the error is in the attached pictures.
(CID:106892092)
Hi, try to read with 331020 instead. Thanks
(CID:107448170)
Modbus TCP output only able to start from register 31000 as the option when you generate the register list "Please choose a register value between 31000 and 39999" So you may need to read as Input register, @31000, and in Modbus address, the register address will be 331000
(CID:107448172)
Hi Kaloyan Georgiev, did you try the suggestions above? Best, Stine
(CID:107448177)
Hello, I tried and I have a success. The problem was that instead of address 31020 i should use 331021. Now everything is OK. Thank you for the support! Regards, Kaloyan
(CID:107448176)
That's great news, Kaloyan Georgiev! Thanks for sharing. Regards, Stine
(CID:107448178)
Posted: 2020-07-03 04:53 AM . Last Modified: 2023-10-31 10:44 PM
