DCE Sensor Web-Service
  • EcoStruxure IT forum
  • DCE Sensor Web-Service
124
65
Back to EcoStruxure IT forum
aashraf
Lieutenant JG aashraf Lieutenant JG
Lieutenant JG
Posted: ‎2020-04-26 05:59 AM
1311
Dears,
Regarding the SOAP APIs of DCE, Specially for Sensor web service.
I Know that using Sensor web service methods we can get any sensor value/measurement.
The question is, Does this service work also for virtual sensors created on DCE or only work for sensors which represent an actual device?
Ahmed Ashraf
Admiral
Posted: ‎2020-04-26 06:37 AM . Last Modified: ‎2020-04-26 06:45 AM
Ahmed,
You should be able to pull historical data for virtual sensors in the following manner:
  1. Use ISXCentralDeviceServices_v2 > getAllDevices to pull the list of devices and find the virtual device.  Use the IS, <ns2:id>, value for that device in the below steps.
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:isx="http://www.apc.com/stdws/xsd/ISXCentralDevices-v2">
    <soapenv:Header/>
    <soapenv:Body>
    <isx:getAllDevicesRequest>
    <!--Optional:-->
    <isx:locale>?</isx:locale>
    </isx:getAllDevicesRequest>
    </soapenv:Body>
    </soapenv:Envelope>
    PARTIAL RESULTS (limited to only the virtual device due to length of results)
    <ns2:ISXCDevice xmlns:ns2="http://www.apc.com/stdws/xsd/ISXCentral/2009/10">
       <ns2:ISXCNamedElement>
          <ns2:ISXCElement>
             <ns2:ISXCElementType>DEVICE</ns2:ISXCElementType>
             <ns2:id>B1db239_nbCustomSensorEncEBAB9071</ns2:id>
          </ns2:ISXCElement>
          <ns2:name>Test-2</ns2:name>
       </ns2:ISXCNamedElement>
       <ns2:ISXCCommState>OFFLINE</ns2:ISXCCommState>
       <ns2:ISXCDeviceType>UNKNOWN</ns2:ISXCDeviceType>
       <ns2:hostName/>
       <ns2:ipAddress/>
       <ns2:location/>
       <ns2:modelName>Virtual Device</ns2:modelName>
       <ns2:modelNumber/>
       <ns2:parentID>B1db239</ns2:parentID>
       <ns2:serialNumber/>
       <ns2:ISXCDeviceState>NONE</ns2:ISXCDeviceState>
       <ns2:supplemental xsi:nil="true"/>
    </ns2:ISXCDevice>
  2. ISXCentralSensorService_v2 > getSensorsForDevice.  Plug the value from step 1 into the <isx:ISXCElementID> field in the request.  This will display a list of sensors associated to that virtual device.
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:isx="http://www.apc.com/stdws/xsd/ISXCentralSensors-v2">
       <soapenv:Header/>
       <soapenv:Body>
          <isx:getSensorsForDeviceRequest>
             <isx:ISXCElementID>B1db239_nbCustomSensorEncEBAB9071</isx:ISXCElementID>
          </isx:getSensorsForDeviceRequest>
       </soapenv:Body>
    </soapenv:Envelope>
    RESULTS
      <ns2:ISXCElement>
        <ns2:ISXCElementType>SENSOR</ns2:ISXCElementType>
        <ns2:id>B1db239_nbCustomSensorEncEBAB9071_CUSTOMSENSOR_40F5AB4D</ns2:id>
      </ns2:ISXCElement>
  3. Grab the ID, <ns2:id>, of the sensor that you wish to grab historical data for.
    <ns2:ISXCElement>
    </ns2:ISXCElement>
  4. ISXCentralSensorService_v2 > getHistoricalSensorData.  Plug the value for <ns2:id> (sensor ID) into this request.  Note that some of the fields are optional, and example date/time values are listed.
       <soapenv:Header/>
       <soapenv:Body>
          <isx:getHistoricalSensorDataRequest>
             <!--Optional:-->
             <isx:endDate>2019-10-23T03:54:37.894-04:00</isx:endDate>
             <!--Optional:-->
             <isx:locale></isx:locale>
             <!--Optional:-->
             <isx:maxDataPoints>100</isx:maxDataPoints>
             <isx:ISXCElementID>B1db239_nbCustomSensorEncEBAB9071_CUSTOMSENSOR_40F5AB4D</isx:ISXCElementID>
             <!--Optional:-->
             <isx:startDate>2019-10-20T03:54:37.894-04:00</isx:startDate>
          </isx:getHistoricalSensorDataRequest>
       </soapenv:Body>
    </soapenv:Envelope>
    RESULTS
    <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
       <soap:Body xmlns:ns1="http://www.apc.com/stdws/xsd/ISXCentralSensors-v2">
          <ns1:getHistoricalSensorDataResponse>
             <ns1:ArrayOfISXCSensorData>
                <ns2:ISXCSensorData xmlns:ns2="http://www.apc.com/stdws/xsd/ISXCentral/2009/10">
                   <ns2:timeStamp>2019-10-20T20:01:30.347-04:00</ns2:timeStamp>
                   <ns2:units>W</ns2:units>
                   <ns2:value>36.70000076293945</ns2:value>
                   <ns2:ISXCValueType>UNKNOWN</ns2:ISXCValueType>
                </ns2:ISXCSensorData>
                   <ns2:timeStamp>2019-10-20T20:06:10.913-04:00</ns2:timeStamp>
                   <ns2:value>33.20000076293945</ns2:value>
                   <ns2:timeStamp>2019-10-20T20:11:09.244-04:00</ns2:timeStamp>
                   <ns2:value>39.0</ns2:value>
    ...100 results in total...
Kind Regards,
Cory
Admiral
Ahmed,
    <soapenv:Header/>
    <soapenv:Body>
    <!--Optional:-->
    </soapenv:Body>
    </soapenv:Envelope>
          <ns2:ISXCElement>
          </ns2:ISXCElement>
       <ns2:hostName/>
       <ns2:ipAddress/>
       <ns2:location/>
       <ns2:modelNumber/>
       <ns2:serialNumber/>
    </ns2:ISXCDevice>
       <soapenv:Header/>
       <soapenv:Body>
       </soapenv:Body>
    </soapenv:Envelope>
    RESULTS
      <ns2:ISXCElement>
      </ns2:ISXCElement>
    <ns2:ISXCElement>
    </ns2:ISXCElement>
       <soapenv:Header/>
       <soapenv:Body>
             <!--Optional:-->
             <!--Optional:-->
             <!--Optional:-->
             <!--Optional:-->
       </soapenv:Body>
    </soapenv:Envelope>
    RESULTS
Kind Regards,
Cory
