Posted: 2020-07-02 09:05 AM . Last Modified: 2024-04-10 01:19 AM
Can someone tell me if a restore from backup will overwrite the network information entered into a DCE appliance prior to the restore?
(CID:92537211)
Posted: 2020-07-02 09:06 AM . Last Modified: 2024-04-10 01:19 AM
Hi Richard,
The DCE appliance will keep the network information configured (IP address, subnet mask, gateway, DNS, secondary DNS, etc) when you restore from a backup that has different network information. So if you are restoring a backup created on a physical DCE into a DCE virtual appliance, the DCE virtual appliance's network configuration will stay as configured and will not take the network configuration (IP address, DNS, Gateway etc) of the backup.
Make sure that when you restore from a backup from a different machine, to have the same or higher hardware spec as the physical/virtual machine.
Let me know if this is what you are referring to.
Breda
(CID:92537228)
Hi Richard,
Breda
(CID:92537228)
(CID:92537353)
No it doesn't overwrite the Network info but it does over write the private network IP info if you have configured the second Network adapter. Depending on how much data you have, you may need 2 virtual disks. Our hardware server only has 1 hard drive but the VM had to have 2 drives for it to work properly. Thick provisioning as well.
(CID:100340208)
Posted: 2020-07-02 09:06 AM . Last Modified: 2023-10-31 10:28 PM
