DCE Object not showing up in DCE.
  • EcoStruxure IT forum
  • DCE Object not showing up in DCE.
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 04:40 PM . Last Modified: ‎2024-04-09 02:43 AM
507
I have a Full rack with 2 RPDU 30A (one each side A&B) I cannot get one to have a association with its DCE object.
(CID:103585757)
  • Data Center Operation
Replies 4
Nothing shows under external systems
(CID:103585758)
Posted: ‎2020-07-02 04:41 PM . Last Modified: ‎2024-04-09 02:43 AM
Hello Aric, Can you elaborate a little more? How are the RPDU connected to the network? Is DCE monitoring each RPDU via its own IP address or are you using port sharing? Can you provide screen shots of the issue that you are experiencing? Thanks Victor
(CID:103585802)
Hi Aric,
As mentioned by Victor, a little more description and screen capture(s) illustrating the issue would have been really useful.
I was wondering perhaps the following might be useful for you:
1. add your DCE server as an external system to DCO (System Setup > External System Configuration). The following page describes the instructions:
Configuring StruxureWare Data Center Expert Integration
2. Then in "Planning Device Association" mode, it should be possible to associate the live data from your added DCE. For more info, please visit the following page:
Associating Live Data from an External System to the Layout
Hope this helps,
Kind regards
(CID:103586011)
Posted: ‎2020-07-02 04:41 PM . Last Modified: ‎2023-10-31 10:27 PM
