Posted: 2020-07-02 04:40 PM . Last Modified: 2024-04-09 02:43 AM
the drop down for 41 is not available, I am assuming this is because there are no single breakers setup, how would you add breaker types to the drop down?
(CID:103585743)
Hello Aric,
Breakers must be added to your genomes from the genome library before it is available to be used within a breaker panel. Please see the URL below for instructions to add a genome to your working genomes from the genome library.
Working with the Genome Library and Genomes
Victor
(CID:103585745)
I get a 404 on that link
(CID:103585746)
Please remove the " " around this link and give that a try "http://dcimsupport.apc.com/display/UADCO8x/Working+with+the+Genome+Library+and+Genomes"; If you are still having issues with the link, please search "working with the Genome Library". That should bring up the same information. Thanks Victor
(CID:103585747)
Hi Aric, This link works: http://dcimsupport.apc.com/display/uaop74/Working+with+the+Genome+Library+and+Genomes Best regards, Pernille
(CID:103585964)
Posted: 2020-07-02 04:40 PM . Last Modified: 2023-10-31 11:39 PM
