Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
DCE Backup Failure.
  • EcoStruxure IT forum
  • DCE Backup Failure.
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 08:05 PM . Last Modified: ‎2024-04-03 01:20 AM
799
DCE Backup Failure.
Hi there
i have a automatic backup created in DCE and it regularly fails.
It mounts ok however generally it has the following error afterwards.
/13/19 07:15:12.947 ERRR - Unable to write to file: /data/tmp/bwDefaultSpace.bak
(com.netbotz.server.services.backup.impl.BackupBotzwareUtil)
I have tried setting it to run on different days and times when server may not be as busy etc however still fails randomly
I can run it manually and it will run fine. sometimes fails as above.
Where should I start looking to resolve?
cheers
Bruce
(CID:145424808)
Hi Bruce Phillips, thanks for posting!
I'll see if I can get some eyes on this. If your issue is urgent, I recommend you contact your local tech support.
Stine
(CID:145851056)
Hi there
No its not urgent. It's a intermittent failure. This weeks backup worked first time
cheers
Bruce
(CID:145851387)
Posted: ‎2020-07-05 08:05 PM . Last Modified: ‎2023-10-22 01:14 AM
