DCE 7.6 - incorrect reading with ACRD 301
  • EcoStruxure IT forum
  • DCE 7.6 - incorrect reading with ACRD 301
126
65
Back to EcoStruxure IT forum
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2021-01-06 04:32 AM
3333
Dear All,
We are getting incorrect readings from inRow ACRD301 (rd3xx -v6.6.4k, aos - 6.6.4). The temperature values in Celcuis are read in values of Fahrenheit (the voltage values are incorrect as well) as attached. We also found that the status of Inrows are all in Standby (but in fact 2 units are running).
We are using DDF - apc_acrd2g ver 14 but no luck.
Anyone encounter this before?
BR
TJ
tjlaw
Lt. Commander
Posted: ‎2021-01-11 05:01 PM . Last Modified: ‎2021-01-11 05:02 PM
In response to Anonymous user
Dear All,
It seems that upgrading the InRow firmware to AOS 682 solved the issue.
Closing the case.
BR,
TJ
Replies 4
Posted: ‎2021-01-07 12:43 AM
3314
Hi TJ,
Can you do an SNMP walk of the cooler?
It is possible that this is not a DCE issue but that the cooler is presenting the wrong information to the DCE.
-Gavan
tjlaw
Lt. Commander
Posted: ‎2021-01-08 06:01 AM
Hi Gavan,
Thanks for the suggestion. I will upload the walk files once I gather them.
BR,
TJ
tjlaw
Lt. Commander
Posted: ‎2021-01-10 11:53 PM
Hi Gavan,
Attached with the SNMP walk from DCE.
BR,
TJ
tjlaw
Lt. Commander
Dear All,
Closing the case.
BR,
TJ
