Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-05 09:39 PM . Last Modified: 2024-04-03 12:44 AM
DCE only capturing 1 sec camera clips for NetBotz P160 cameras. Camera motion would be 10 to 20 seconds at a minimum.
NetBotz
DCE
(CID:148341517)
Hi Barry,
Usually the one second clip issue is if you're trying to send to too many DCE servers. The following link is to a k-base that refers to this issue:
http://www.apc.com/us/en/faqs/FA158397
It mentions the older ISXC but it is still the same with the newer DCE.
On a side note, the first image you attached for camera capture on the bot is for alerting. This does not effect the surveillance image count or resolution on V2 or V3 NetBotz.
Steve.
(CID:148341880)
H Steve, thanks for the response, we currently have only one DCE server. All NetBotz have the following setup for DCE server.
(CID:148341966)
Posted: 2020-07-05 09:39 PM . Last Modified: 2023-10-22 01:13 AM
