import AD user to DCO 8.2.2
  • EcoStruxure IT forum
  • import AD user to DCO 8.2.2
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 09:40 PM . Last Modified: ‎2024-04-03 12:44 AM
614
I am planning to use AD for user authentication, but I could not find a document for step 2 below :
1  AD server set up in DCO ( doco already exist and I got it)
2 import users from AD group ( I could not find any article so far)
3 user right or assign user to group after imported to DCO
Cheers
(CID:148341613)
  • Data Center Operation
616
Hi Jimmy,
For the point 2. there is only an gif (howtoConfirmADsetup.gif) at the bottom of the page https://sxwhelpcenter.ecostruxureit.com/display/public/UADCO8x/Setup+an+AD+%28Active+Directory%29+Se...
In the User Groups window, click on "Add" then select the "Auth. Server" type. you can then select your AD server and look for your AD group
You will get then a group with subtitle "Managed by authentication server"
In the group settings, you can configure the permissions like "Operations" groups
Regards
Yannick
(CID:148341625)
Yannick, I have successfully added a new user group using AD server for authentication, but I was not able to import the user from the AD user group. The new AD user group property showed:
Users
User Group relations to Users are managed by authentication server.
Have I missed anything, Can you provide more detail step to resolve it?
(CID:148342349)
Posted: ‎2020-07-05 09:40 PM . Last Modified: ‎2023-10-22 04:39 AM
