Posted: 2020-07-02 02:04 PM . Last Modified: 2024-04-09 04:18 AM
I loaded a new SSL cert from Comodo Security Services
Console shows FAILED for httpd start (see attached image)
Help please
(CID:99156923)
Hi Ed, thanks for posting. @community - hints, solutions?
(CID:99156934)
Hi Ed,
You'll need to contact support directly on this. Unless you created a backup just prior to this cert being added or you can restore easily, someone will need to access the back end of the server for / with you and remove the cert. If this is a chain cert, that is likely the issue but you'll need some more in-depth troubleshooting. See internal k-base FA225533
Steve
(CID:99156967)
I have the same issue with DCE 7.3.1. How can contact directly the support?
(CID:110005046)
Hi Yannic, Please check the APC web page under your region. If you go to support on the top menuand (in US anyway) support again, it will bring you to the correct regional link with support numbers and e-mails similar to this one for the US: http://www.apc.com/us/en/support/contact-us/index.jsp Steve.
(CID:110005189)
Hi All,
In case anyone else was wondering FA239971 explains the format that SSL certificates need to be in to be added to DCE for client and web communications.
http://infomanager.schneider-electric.com/itb/index?page=content&id=FA239971
(CID:99157302)
Posted: 2020-07-02 02:04 PM . Last Modified: 2023-10-31 10:24 PM
