Posted: 2020-07-02 02:03 PM . Last Modified: 2024-04-09 04:19 AM
Hi All,
I was wondering if anyone knows how to change the IP on an AP7611 PDU. This type of PDU is discontinued and I can't find the user manual online.
One of my Field Service Engineers is on site servicing these units.
(CID:99156916)
Hi William, thanks for posting. There might be a delay in addressing this issue as a few of our customer support Team members are on holiday. Stay tuned!
(CID:99156933)
Posted: 2020-07-02 02:03 PM . Last Modified: 2024-04-09 04:18 AM
Hi William,
This is one of the older PDUs that communicates using the DCAL protocol. You may recall the vertical gray PDUs that also used this protocol. The only way to IP these devices is to put them on the private LAN for either DCE with DHCP enabled or ISX Manager. They wil lget IPs automatically. they can't be IPd manually.
Steve
(CID:99156974)
Posted: 2020-07-02 02:04 PM . Last Modified: 2023-10-31 10:20 PM
