Copy or inherit thresholds to newly discovered devices?
  • EcoStruxure IT forum
  • Copy or inherit thresholds to newly discovered devices?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 04:21 PM . Last Modified: ‎2024-04-09 02:50 AM
818
I have configured a set of threshold alarms on one device and would like every new device to have the same settings.
Is there an easy way to achive this or do I have to choose all the new devices and configure the thresholds every time?
(CID:103585110)
Replies 5
817
Hi Patrik!
Unfortunately, you need to create new tresholds manually.
I hope, that it will be realized in future releases, but we have no such functionality at the moment/
(CID:103585112)
Valentin, I have a very similar issue, i need to make threshold changes to 104 RPDU's, was thinking of mass configuration but unfortunately i do not see this functionality.
Is there any other way i can proceed without changing these PDUs manually?
Thank you for your assistance.
Regards
(CID:126179286)
HI!
If you need to change existing thresholds, you should switch to Alarm Configuration perspective, then choose thresholds you need and right click on it and choose "Edit threshold". Just make changes and it will be implemented on all choosen thresholds.
If you want to create new threshold, just choose rPDU's you need right click and select "Create new threshold". Then set values.
(CID:126179477)
Thank you for your speedy response.
If i am understanding you correctly, when in Device Alarm Configuration, i simply highlight all the RPDU's that i need to edit threshold, right click and make the changes?
Is this correct?
(CID:126179990)
Posted: ‎2020-07-02 04:21 PM . Last Modified: ‎2023-10-31 10:22 PM
