Posted: β2020-07-02 12:44 PM . Last Modified: β2024-04-09 11:44 PM
Dear Team,
KIndly assist on the configuration of the AP9635CH NMC to 66061 Jbus/Modbus card on G5500 UPS.
This cards came separately from the UPS and after the physical connection of the two cards on the UPS, AP9635CH cannot load up the UPS values as shown.
Felix
(CID:96764813)
Hi Felix!
You need to properly configure UPS settings and Modbus communication between cards.
Contact your local tech support for futher assistance.
(CID:96764838)
Hi Valentin, Well noted, thanks. Regards, Felix
(CID:96765097)
Hi Felix,
66061 us default setting, check RS485 wiring ?
Dominique
(CID:96764844)
Hi Dominique, Thanks for your contribution, I got it working. Regards Felix
(CID:96765096)
Posted: β2020-07-02 12:44 PM . Last Modified: β2023-10-31 10:21 PM
