An error occured
  • EcoStruxure IT forum
  • An error occured
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 12:45 PM . Last Modified: ‎2024-04-09 11:44 PM
634
An error occured
Hello Team,
can You  advice on this?
Please see image:
SESSION 2015-05-13 07:54:04.261 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_45
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=lt_LT
Framework arguments:  -application com.apc.isxo.client.bootstrap.application
Command-line arguments:  -os win32 -ws win32 -arch x86 -application com.apc.isxo.client.bootstrap.application -clean
!ENTRY com.apc.isxo.client.bootstrap 1 0 2015-05-13 07:54:27.744
!MESSAGE Downloading to: /C:/Program Files/StruxureWare Data Center Operation 7.3.5/application/dropins
!ENTRY com.apc.isxo.client.bootstrap 1 0 2015-05-13 07:54:36.427
!MESSAGE Logging in to xxx
!ENTRY com.apc.isxo.client.bootstrap 1 0 2015-05-13 07:54:45.564
!MESSAGE Time to download: 0s
!ENTRY com.apc.sma.client 1 0 2015-05-13 07:56:58.620
!MESSAGE JVM args: [-Xms256M, -Xmx768M, -XX:+UseConcMarkSweepGC, -XX:+CMSIncrementalMode, -XX:+CMSIncrementalPacing, -XX:MaxPermSize=192M, -Dfile.encoding=utf-8, -DbuildType=Release, -Dosgi.bundlefile.limit=0, -DsyncProduct=OPERATIONS, -Dosgi.nls.warnings=ignore]
!ENTRY org.eclipse.equinox.security 4 0 2015-05-13 07:56:58.682
!MESSAGE Could not locate JAAS Configuration with name "xxx", verify that the configuration exists and is non-empty.
!ENTRY org.eclipse.equinox.security 4 0 2015-05-13 07:56:58.691
!ENTRY com.apc.isxo.security.SecurityActivator 4 0 2015-05-13 07:56:58.704
!MESSAGE Failed to log in: No LoginModules configured for xxx
(CID:96764831)
  • Data Center Operation
Hi Michail,
It seems the issue is basically the location of the client temporary files, which seems to be currently on a network drive, right?
The following web page contains details and instructions to change the location of the client temp files:
Similar instructions for 7.3.x & 7.4.x
Changing the location of the StruxureWare Data Center Operation Client temporary files
Changing the Location of the StruxureWare Data Center Operation Client Temporary Files
By the way, it is strongly recommended considering the product upgrade, as you might know there have been several releases since 7.3.5.
(CID:96764851)
Posted: ‎2020-07-02 12:45 PM . Last Modified: ‎2023-10-31 10:15 PM
