Posted: 2020-07-02 03:56 PM . Last Modified: 2024-04-09 02:59 AM
Just to verify, from the explanation, looks like its feasible to have multiple users (FSEs) concurrently configuring the same DCO, as long as rooms configured are under different folders in DCO.
We are proposing a DCO for 3 different DCs (each DC has multiple floors & rooms), and is trying to reduce the estimated deployment time by concurrently deploying 3 DCs at the same time, else we'll spend > 6 months onsite.
From my test here with 2 users on DCO750, seems to indicate that way for different root folders, but does not seem to work if 2 users are working on different room or folder under the same root folder, i.e ended up with save conflicts.
Thanks for confirmation!
Understanding what Happens when Multiple Users Work Simultaneously in DCO
(CID:103583904)
Hi Christopherus,
That's correct, in a multi-user environment, the on-line users should avoid creating rooms in the same folder. As a sort of work around, I would suggest to create the rooms firsts, and then let the users go on-line and do the job.
Kind regards
(CID:103583908)
Posted: 2020-07-02 03:56 PM . Last Modified: 2023-10-31 10:20 PM
