Posted: 2020-07-02 11:12 AM . Last Modified: 2024-04-10 12:38 AM
Hi!
Could anyone explain dependence of the color tiles?
On what basis they change?
What color codes means (what is the best, what is worst case)?
Thanks!
(CID:94602767)
Hi Valentin Kozlov
Are these the color tiles you are referring to? If not, could you please take a screenshot to explain your question.
(CID:94602816)
Hi Valentin Kozlov
(CID:94602816)
Yes, these tiles. What mean green, red, blue? It's only informational or mean some severity level?
(CID:94602823)
Color of the tile matches the airflow level, according to the current scale. Color of the tiles may change if the scale have changed - for example, an additional tiles are installed.
(CID:94602829)
How do I change from Meters to feet?
(CID:105469210)
Posted: 2020-07-02 11:13 AM . Last Modified: 2024-04-10 12:38 AM
Hi rsnowfl, sorry just noticed your comment. You should have posted it as a separate question to make it more visible. StruxureWare Data Center Operation uses measurement units specified by operating system of your computer. For example, if your regional settings are US, DCO runs in English, uses feet, dollars and cubic feet per minute. If you change your regional settings to Ireland, you get English language, meters, euro and meter per second as measure of airflow. You can read more about language options here: https://dcimsupport.apc.com/display/UAOp74/Working+With+Multiple+Languages
(CID:105470382)
The colours of the arrows are referring to the speed of the air under the floor, measured in meter per second (m/s)
The colours of the floor tiles are referring to the amount of air that are pushed through the tile(s), measured in cubic feet per minute (cfm).
(CID:94602888)
Posted: 2020-07-02 11:13 AM . Last Modified: 2023-10-31 10:20 PM
