Adding An Email Alert To DCO Error/Alarm
  • EcoStruxure IT forum
  • Adding An Email Alert To DCO Error/Alarm
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:13 AM . Last Modified: ‎2024-04-10 12:38 AM
949
I currently have an external system (StruxureWare Central) that is mapped to devices in DCO, when an error/alarm is generated from this device it appears in the Alarms tab in DCO but is there anyway to assign an email alert so if the alarm triggers DCO sends an email out?
I know this is possible in DCE but as this external system just feeds into DCO can I setup email alerts?
(CID:94602795)
  • Data Center Operation
949
Hi James,
It is not possible to send email alerts from DCO. This has to be set up in DCE since this is the monitoring tool.
You will have to configure an alarm action in DCE that sends out an email.
Hope this answers your question.
Jesper
(CID:94602798)
Replies 6
950
Hi James,
Jesper
(CID:94602798)
Jesper As this is an external system that is generating alarms unless we have access to configure the email setting on the system it won't be possible to send an email?
(CID:94602799)
Hi James, That is correct you can not configure DCO to sent out email alerts. This should be done in DCE. The only emails that can be sent from DCO is in relation to work orders in the Change module. But this is work orders that are sent out, not alerts. Thanks Jesper
(CID:94602800)
Posted: ‎2020-07-02 11:13 AM . Last Modified: ‎2024-04-10 12:37 AM
Jesper, Thanks for the answer. I understand DCE is the alerting tool but it maybe be a good feature to allow DCO to send out emails for external systems as they may be managed by another party. This would negate the need to contact them and ask them to configure an email address.
(CID:94602810)
Posted: ‎2020-07-02 11:14 AM . Last Modified: ‎2024-04-10 12:37 AM
James. I have added your request to our feature request system. The request will now be evaluated by product management. If you want to add feature requests in future you can do it here on EcoStruxure IT Help Center also. In the green bar on top of this page you will find a link to our feature request form. Thanks Jesper
(CID:94603343)
Posted: ‎2020-07-02 11:14 AM . Last Modified: ‎2023-10-31 10:13 PM
