Posted: 2020-07-05 02:00 PM . Last Modified: 2024-04-04 12:19 AM
Is there a way to change the port number after the Ecostruxure IT Gateway installation?
As far as I know, when user install the gateway, the following numbers are configurable.
This time, I'd like to change the port numbers after the installation of IT gateway.
Is there a way to do that?
Especially, I'd like to know how to change the port number for database server.
Akihiro
(CID:135432510)
Dear Akihiro Yamagami,
Regarding your question:
...Especially, I'd like to know how to change the port number for database server.
The answer to my topic should help you with this. SxW Portal is of course different from the EcoStruxure IT Gateway software, but in terms of configuring the PostgreSQL service port, you need to do the same.
If you have more questions, please ask.
With respect.
P.S.: Unfortunately, I cannot write the answer to your question Failed to install Ecostruxure IT Gateway 1.4.3 and unable to uninstall, since this topic was closed for public viewing ☹️ (available only for =SE= employees). However, your workaround, that is, switch to the English locale, and then back to yours, really works 😀.
(CID:137103464)
Hello spezialist,
Thank you for your comment and sorry for my late response.
To change the port number, thank you for your information.
Concerning about the Failed to install Ecostruxure IT Gateway 1.4.3 and unable to uninstall, thank you for your confirmation.
P.S.
I also tried to fix it to public but it failed because of system error...
Akihiro Yamagami
(CID:137106678)
Ok, thanks for the feedback.
(CID:137106764)
Posted: 2020-07-05 02:00 PM . Last Modified: 2023-10-20 05:08 AM
