Posted: β2020-07-04 04:12 PM . Last Modified: β2024-04-05 12:18 AM
Hi ,
Need a support to change mass SNMPv1 community string from public to new name . Can any one please provide me how do we do this and what will be the impact do i have to change this name on DCE as well ?
(CID:130092054)
Dear Shaik Mahboob Ali,
Of course, this can be done using DCE software. Step by step how to do it I described in the recent topic . The only difference is only in the choice of parameters for editing, for example as it is shown in my screenshot:
Try it, it should work for you.
With respect.
(CID:130092130)
With respect.
(CID:130092130)
(CID:130092157)
Ok, thanks for the feedback π.
(CID:130092163)
Hi ,
I am getting communication lost and cannot see any values on web and displayed as devices unplugged but i can access the device. What could be the issue ?
(CID:130092246)
Posted: β2020-07-04 04:12 PM . Last Modified: β2024-04-05 12:17 AM
updated below picture from one of the device failed to contact with server.
(CID:130092251)
1. Have you changed the public community string to your own secret string on the DCE-server as I explained it in your topic ?
2. Next, you changed the public community string to your own secret string (similar to the item 1) on your device, as I explained in this topic in the screenshot above?
From what device is this screenshot? Can you show it where you could see the description of the error or problem?
In addition, usually SNMP devices do not initiates a communication with the DCE-server, but on the contrary: the DCE server initiates a communication session using the SNMP protocol with the device. Therefore, the problem with communication can be seen on the DCE-server, but not on the device as you explain it.
With respect.
(CID:130092264)
Posted: β2020-07-04 04:13 PM . Last Modified: β2024-04-05 12:17 AM
Thanks i missed to change the community string from SNMPv1 settings from pic below location as well.
(CID:130092441)
Congratulations, you have succeeded π.
(CID:130092476)
Don't forget to change the DCE's SNMP scan settings' SNMP v1 Read community name afterwards
Device Scan Settings option 8052735a
(CID:130092140)
That's right, since I wrote in response to topic .
(CID:130092146)
Posted: β2020-07-04 04:13 PM . Last Modified: β2023-10-20 05:08 AM
