Posted: 2020-07-04 04:13 PM . Last Modified: 2024-04-05 12:17 AM
I want to install a Disaster Recovery server for our customer's DCO. I installed a standalone server and done all the configurations. When I try to define the DR server from webmin, I get the error below.
I checked the file under that folder but nothing seems wrong.
What should I do now?
Thanks in advance
(CID:130092220)
Hi Erhan,
Seems to be a configuration issue, apparently you have not accepted the fingerprint and allowing DR node to connect. Please read the configuration instructions described here:Disaster recovery
Kind regards
(CID:130092892)
Hi Erhan,
Kind regards
(CID:130092892)
Posted: 2020-07-04 04:14 PM . Last Modified: 2024-04-05 12:17 AM
Hi Jef,
I have read all the configurations and there is no button to accept the fingerprint. I get the error when I try to allow disaster recovery note to this node which I am currently using.
Are there any other option to accept the fingerprint?
Best regards,
(CID:130682622)
Hi Erhan,
We will review the documentation - Please take a look at the following tip shared moment ago (it contains every single step, including accepting the fingerprints):
Kind egards
(CID:130683158)
Posted: 2020-07-04 04:14 PM . Last Modified: 2023-10-20 05:09 AM
