Posted: 2020-07-04 05:20 PM . Last Modified: 2024-04-04 11:57 PM
Good Day,
How do I get advanced view to show the temperatures in Deg C from Deg F? I tried changing the time zone to a different one but it's not changing.
(CID:131336374)
Dear terrence ramnarine,
From my answer to the topic :
If you locale is U.S. then it's normal, the temperature should be in Fahrenheit 😀.
Try to change another locale or: to change the readings on Celsius, try in Windows 10 to go to Control Panel -> Region -> in Formats tab -> Additional settings... -> Measurement system: Metric:
I hope this helps you.
With best regards.
(CID:131336446)
With best regards.
(CID:131336446)
Have you been able to solve your problem or not?
With respect.
(CID:131961157)
Posted: 2020-07-04 05:20 PM . Last Modified: 2023-10-20 05:08 AM
