Change DCO webservices port from 8080 to 80 or 443
  • Change DCO webservices port from 8080 to 80 or 443
127
65
Posted: ‎2020-07-03 01:44 AM . Last Modified: ‎2024-04-09 12:30 AM
833
All, I got a question from a customer, regarding (SOAP) webservices DCO: is it possible to change the current port 8080  to port 80 or 443 , and if yes what is the procedure to change
(CID:105470327)
  • Data Center Operation
833
When you set up e.g. SoapUI to use our web services, it will generate requests using port 8080. However, you can simply change the address manually and use HTTP (port 80) or HTTPS (port 443).
In other words, you can change e.g. http://:8080/isxo/webservices/equipment/InventoryWebService-v2 to https:///isxo/webservices/equipment/InventoryWebService-v2.
See StruxureWare Data Center Operation Web Service API for information on the specific web services.
(CID:105470365)
Replies 5
834
(CID:105470365)
Hi Martin, THX a lot for you're response but customer came back with the following response, when they use the link like you mentioned: https:///isxo/webservices/equipment/InventoryWebService-v2 then they notice that within this page the soap address link is hardcoded to port 8080, see screenshot , so when they download this to a local file and change it then it works but they like to have a option the have this changed in "real time" without having to change it manually, is that possible ??
(CID:105470394)
Unfortunately, you have to manually use the correct address.
(CID:105470395)
THX Martin
(CID:105470422)
Posted: ‎2020-07-03 01:44 AM . Last Modified: ‎2023-10-31 10:20 PM
